Barn of Parts DIY Puller template for Brake Caliper Removal
hibshman25
Vendor
Lebanon, PA 17042
2017 sidewinder ltx dx
2018 snoscoot
Had a customer inquire about making a puller to pull caliper and bearing assembly that was bound to drive shaft via Loctite. I drew up a simple template which allows one to center punch the holes into a flat piece of steel. Drill out the 3 holes and then obtain some longer bolts. Place the plate against the end of shaft and thread the 3 longer bolts into the tapped holes in caliper. Work your way around snugging up bolts a few turns at a time to progressively draw the caliper off the shaft.
The template is attached.
Thanks for sharing. It has been printed and saved for future use Incase !
