Barn of Parts Heavy Duty Lower Center Shock Cross Shaft
Do you sell an upper shaft similiar to the RR?
Yes he does,$45.00 for shaft and washers,it slides over the stock shaft,if your stock shaft is slightely bent like mine was,bang hard with hammer to slide thru.
Just to confirm as I'm going to install mine. You still use the aluminum sleeves and washers on each sides?
If so, to bad cause its hiding that nice stainless.
