DaveyBoy
u got a pm
welterracer
The purpose of the plastic screws is to break off if you roll it verses crushing the dash.. It is a great idea..
Dont over tighten them.. .just barely seat them..
snomonut
apexer said:Has anyone put one of these on a blue Attack? If so how about a picture.
OK, I promised some pictures and finally got the windshield re-installed....ordered new bolts and rubber nuts and they just came in today. Also took a couple with the new hooked brake lever that some have asked about.
cgwiz
Nice!!!
studdog
nice combination with chrome windshield and siver and blue on sled. looks great! studdog. Is the longer brake lever still adjustable for lever distance to hand grip? studdog
snomonut
No. You lose the adjustability feature. I will say that it does feel right though....
MR.HAPPY
- Sep 30, 2003
- GREAT NORTH OF... ILLINOIS?
- YAMAHA
What brand of brake lever did you use?
I used them for years & loved them with the hooked bars, but got tired of customizing the bars to look good!!!
BR
BR
snomonut
It's a Yamaha accessory. Part #SMA-LEVER-00-00 $34.95
Kevin from Port told us how nice the lever was while visting with him at the Milwaukee show....thanks Kevin!
Pureadrenaline
snomonut I noticed that you aleady put your skid plate on. Could you tell me what you had to do and what tools are needed.
Thanks,
-Pure-
Thanks,
-Pure-
snomonut
Pureadrenaline said:snomonut I noticed that you aleady put your skid plate on. Could you tell me what you had to do and what tools are needed.
Thanks,
-Pure-
Pure- a drill, socket wrench, open ended wrench and philips head screwdriver. Yamaha supplies the little tool used to expand the nut inside the belly pan. Just follow the directions, they are pretty well laid out. If possible, use the metric size drill bit they specify, otherwise you'll be routing out the rivet hole with your non-metric bit. Everything lines up easily.
Essentially, you are drilling out 4 rivets on the belly (a sharp drill bit helps), using the special tool to install the nuts inside the belly pan and then screwing it all together!
Nice Rumble
Looks like you have your machine in your living room. You got your priorities straight!
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Hmmm, I only thought that color combo would work with the GT but was wrong. That does look good, matching the exaust covers
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Now thats a way better shield and it looks good as well.
snomonut
Nice Rumble said:Looks like you have your machine in your living room. You got your priorities straight!
I agree.....on the other hand, the wife thinks I'm nuts!
