sxrsist
- Mar 25, 2007
cant find the post on the how to,s is it on here
Jevil
![](/styles/admin.gif)
![](/styles/vip.gif)
thats the ticket ![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
Ganz
What does that big spacer do?
Holds the shift longer before it reaches one to one and you will gain acceleration.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
An alternative to the spacer is to use a Dalton Industries Pink Secondary Spring. In addition to what Mr.Sled posted above the heavier secondary spring also helps improve acceleration when you jab the throttle from idle or when at speed. The stock spring tends to collapse in those situations (especially with bigger tires) which hurts the clutch's efficiency by effectively raising the gear ratio (slowing accel).
Ganz
Does it hurt the top end?
SledFreak
- Feb 7, 2005
- Ontario. Canada
port-parts said:An alternative to the spacer is to use a Dalton Industries Pink Secondary Spring. In addition to what Mr.Sled posted above the heavier secondary spring also helps improve acceleration when you jab the throttle from idle or when at speed. The stock spring tends to collapse in those situations (especially with bigger tires) which hurts the clutch's efficiency by effectively raising the gear ratio (slowing accel).
I will call Dalton about this and see what he says, because I bought my clutch kit from him for my 700 Grizzly and he never mentioned it.
Port-Parts
TY Advertiser
- Sep 18, 2003
- 2012 Nytro RTX
Ganz - the shim or the heavier spring don't seem to affect top-end at all.
Sledfreak - I believe that the majority of this post is about the Grizzly 660 model not the 700. The 660's benefit from the heavier secondary spring whereas the 700's have a stiffer spring from the factory and at this point it doesn't appear a stiffer secondary spring will help the 700's like they do the 660's.
NLGrizzly
- Jul 2, 2006
- Marystown, NL, Canada
- WLM
- dougwarren82@hotmail.com
Would this work on a 600
u bet ![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
shavedheadedyamaha
- Nov 30, 2008
hey whats the specs on the spacers??? i wanna throw some in before i put it all back together...... i have a 98 600 griz
