mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
does the metal ribs on the belly pan tear up the short oil filter that comes in the oil change kits?or do you have to worry about those ribs if you use a aftermarket longer filter?i know if you hit something under the snow that you could be screwed,but are these ribs rubbing on the O.E.M filters?
yamaposer
Yup even the short filters are at risk. Switch out to a Roest skid plate. Very good quality, great looking, no more problem
Dimebag
yamaposer said:Yup even the short filters are at risk. Switch out to a Roest skid plate. Very good quality, great looking, no more problem
X2!
00-NUKE
Bare Minimum I would pull off your stock belly pan, grind the ribs that are in front of your filter down to flush, and run nothing but a stock Yammi oil filter. Anything on top of that can't hurt you.
markowinnipeg
00-NUKE said:Bare Minimum I would pull off your stock belly pan, grind the ribs that are in front of your filter down to flush, and run nothing but a stock Yammi oil filter. Anything on top of that can't hurt you.
X2 took a drumall and ground off the steel ribbing in the area of the filter. I am running Yamaha skid plate on top of stock and in 4 years of riding been no issues....and yes I have hit a few things along the way
Snakebit
Got my Roest in the mail today. All I can say is top shelf item.
Snakebit
Just installed it. Since I had all the panels and 'bottom cover' (I refuse to call that piece of crap an engine protector) off, install took all of 15 minutes, the majority of the time spent bitching at my battery powered drill.
Piece of cake, looks awesome and an easy install; my idea of the perfect product.
bottlerocket
Wouldnt even ride my sled with that stock plate. First look at that and hearing people were making it weaker (by grinding structure) so the oil filter could keep the plate from flexing upward is crazy. Shame on Yamaha for such a oversite and not changing since 2008. Roest plate can or will save your motor on a very short riding season regardless of insurance or warranty.
Hornet Handler
A Roest skid plate is the only way to go for the bottom of a Nytro. Once you see the difference between it and the plastic alternatives, the choice is clear.
Hornet Handler
Got snow out east?
sleddingfarmer
Hornet Handler said:Got snow out east?
Its snowing here in Midwestern WI at the moment. Would be nice to get a little bit of snow, just enough to cover up the corn field we spread cow manure on lol
If we got 1 inch of snow, we'd have a total of about....1 inch of snow.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
Skid plate a must, especially if you are boondocking or going off trail often...
snow broke
bottlerocket said:Wouldnt even ride my sled with that stock plate. First look at that and hearing people were making it weaker (by grinding structure) so the oil filter could keep the plate from flexing upward is crazy. Shame on Yamaha for such a oversite and not changing since 2008. Roeast plate can or will save your motor on a very short riding season regardless of insurance or warranty.
Well Spoken!
bottlerocket
But not well written. I didnt even spell Roest correctly ~ damit!
