i tightened my belt by removing the two shims between the sheeves, but it seemed to mess up the reverse and the belt still sits down to far in the secondary. ant ideas how to tighten up the belt without removing the shims? what number should the stock belt be? also what is the stock setting for the secondary spring, i put mine back at b-1. thanks
Doesn't removing shims lower the belt riding height in the secondary? No manual in front of me at this time, but I'm almost positive you add shims to increase ride height.
ecopter, the Phazer secondary is a different style than previously used on SRX, SX, Apex, RX-1, etc. Yes, you remove shims to tighten up the belt. Tim, I replied to your PM.
