mwolff
I am looking for a video or “how to” info on how to replace/remove the belt “easily” when you have a closed face secondary like the one on my 2007 Venture.
I have watched videos with a open secondary and working the helix in that case is a piece of cake this… well not so much lll
on that style secondary i rotate the inner face of the clutch and push it to inside while forcing belt down into clutch to hold it open for easier removal.
mwolff
Oh man I am trying but belt is covering the majority of the face which makes it a PITA. The fact that my fingers/hands are very weak certainly doesn't help at all.on that style secondary i rotate the inner face of the clutch and push it to inside while forcing belt down into clutch to hold it open for easier removal.
Maybe its hanging up more than I thought making it that much harder?
i grab it by the web on the back side to rotate it with the park brake applied.
mwolff
Thanks for your feedback. Made me go for an idea I had before and hadn’t tried and it worked! So that someone else can benefit here is what I did.i grab it by the web on the back side to rotate it with the park brake applied.
Accessed from backside of secondary with right angle needle nose pliers and used then to rotate the back sheeve while I pulled on the belt.
YukonMP
- Dec 25, 2014
- Yukon Territory
You are a genius man. I always feel like I must be some sort of poodle boy when ever I do that job. Thanks for posting back and sharing.
mwolff
Glad to help. That’s what is great about places like this. People helping people.You are a genius man. I always feel like I must be some sort of poodle boy when ever I do that job. Thanks for posting back and sharing.
I have a lot of experience just none in this field so I’ll learn lots here but I am sure I can help as well.
- 48K
