Oak Hill
- Dec 19, 2004
- Owosso, Mi
- www.airtoolexpress.com
What is the belt deflection specs and load applied?
Slush Monster
I Like to adjust my belt so it rides abought 1 MM out of the secondary clutch to get a good starting ratio. I am not sure what the exact deflection is, but if you get it alittle tight, your belt will squeal at idle usually this will wear in soon. Just dont get it to tight so the sled trys to creep. You can adjust this with the 3 washers on the back of the secondary clutch. To loose, and the sled will sort of stutter when taking off.
