Bent studs
Standish, Maine
Hi, I found 3 bent studs on the inside (center section) of my track yesterday when doing my inspection to get ready to ride. They are bent about 60 deg to 45 deg angels. should I replace them? If I don't replace them what could happen? Also what would be the best way to get them off? (use an angel gringer?) thanks in advance. Sorry if this has been talked about before, I used the serch and couldn't find anything.
I would replace them. You probably will have to grind them off. Take care to not heat them so much that you heat up the track, etc.
