Best Belt to use on Asphalt
RX1DERFULL
Summerside , PEI
Hi I am wondering what everyone believes is the best belt to use on the asphalt.
Boosted 2003 RX-1 (10psi).
I have been using the stock 8DN belt, but feel there may be a better one to use.
Perhaps Mr. Knapp would be willing to make a recommendation.
PM's are welcommed on this one.
Thanks,
RX1DERFULL
I have tried all kinds of belts and went back to stock 8DN yami.
The worst one I tried was the Dayco Ultimax. The fibers felt like a wire brush from the heat, which wore down the sheaves within 10 weekends of asphalt racing. I know I posted this in my asphalt results section. Don't know if it was 2003 or 2004.
Definitely stock Yamaha belt. Try the other brands, you'll see for yourself.
RX1DERFULL said:
Which of the stock belts?
The 00 or the 01?
What are the diferances between the two belts?
I thought the 01 was the only one available from Yamaha these days. Not sure what the difference is, do a search on the site here, there has been discussions about it and ask your dealer what the difference is. With most manufacturers the higher number usually indicates improvements or is a replacement for the original.
