fourbarrel
Building a collection one sled at a time
- Sep 23, 2004
- New Brunswick
- 2019 SRX
I could have sworn I saw billet torsion spring holders for sale somewhere but for the life of me I can't find them now.Is there a company making these? There must be a better alternative to the stock plastic ones.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
you mean the loop that the spring slides through or the block that adjusts tension. Lots of people make the adjusters (barn of parts for one). The loops, even if made from billet, would require some kind of plastic or lower friction surface to slide through or you would risk binding.
Turboflash
- Mar 18, 2019
- Southern MN
Lencco used to make them but I think they're discontinued. Maybe some old stock around?I could have sworn I saw billet torsion spring holders for sale somewhere but for the life of me I can't find them now.Is there a company making these? There must be a better alternative to the stock plastic ones.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
What's wrong with the plastic ones? I've never had one break ever.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Rear Spring Adjuster Blocks - Grip N Rip Racing LLC.
Don't get stranded on the trail or the track with the breakable plastic blocks. Replace them with these unbreakable CNC machined billet aluminum blocks. Redesigned with a 10% increase in spring preload in the medium position and a 15% increase in the high position. Very light weight thru hole...
HABS 1
- Oct 22, 2015
- corunna,ontario
i put the bop ones on... has an extra step over stock ones if u need
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
They don’t break, the nut to adjust them strips thoughWhat's wrong with the plastic ones? I've never had one break ever.
Fords4life
- Dec 7, 2021
- South Dakota
Yamaha had or has the billet blocks also, 4 position, i have two sets on my sleds, been waiting for third set for about a year now.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
I had my BOP version in about 6 days from the day I placed the order.Yamaha had or has the billet blocks also, 4 position, i have two sets on my sleds, been waiting for third set for about a year now.
spare skid has yamaha ones for sr viper. one on the sled has muffin works 5 position ones but are discontinued. i would go with barn of parts ones nowadays.
fourbarrel
- Sep 23, 2004
- New Brunswick
- 2019 SRX
I've seen the billet adjusters but it is actually the loop that holds the long end that I was referring to.Mine aren't broke it's just the sloppy fit onto the steel mount I'd like to see tightened up.I even went and picked up new ones and they aren't even tight on the mount.I ended up cutting a piece of aerosol can up and shimming the slack out.Now the loop sits nice and square where it was kinked sideways before.
KnappAttack
- Feb 19, 2004
- Welch MN
Not if you use a six sided socket they don't. Old two-stroke Cat spark plug sockets from the old tool kit works perfectly.
Turboflash
- Mar 18, 2019
- Southern MN
