Right it is a personal thing. I am 140 and 3.5 turns on rtx. Xtx transfers more so probably not as much needed and a ltx transfers the least so more probably needed. Is a sweet spot and it’s different for everyone I suspect. Easy enough to adjust though.IMO, your weight will not compress it as much as you think. Most people are between 2-4 turns depending on how you like to ride
lilrez
- Feb 7, 2016
- Near Ottawa
What's stock on your sidewinders?
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
The BTX and XTX (2017) have same spring as Viper XTX...my buddies both run stingrays and say big difference.
hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
If you have ltx then steve is right and you are gonna need more. I am at 5 turns and it finally transfers some and thinking I might try 1 more to try and lighten ski pressure some moreRight it is a personal thing. I am 140 and 3.5 turns on rtx. Xtx transfers more so probably not as much needed and a ltx transfers the least so more probably needed. Is a sweet spot and it’s different for everyone I suspect. Easy enough to adjust though.
nickg
- Dec 3, 2018
- roberts,wi
- 2015 yamaha viper sr ltx dx
when you say you turn it 5 turns is that from where the spring is loose like rattling?then tightening from there 5 turns?
rbell14
Snug it up so the spring doesn't rattle or move at all. Then 2-6 turns from that point. I bet 2-3 is where you end up. see link for specific instructions
https://stingraymods.com/shop?olsPage=products/stingray-mods-front-skid-shock-spring
snowhite
Ohhh I received Bills spring this afternoon ! Wow by the looks of it I can tell it’s gonna work! And best part is the fastest delivery yet from his business to my door! Thanks Sir tomorrow it’s going into the skid. Can’t ride though because the top chain case bearing #*$&@ the bed.Waiting for parts.
Oh Man!Ohhh I received Bills spring this afternoon ! Wow by the looks of it I can tell it’s gonna work! And best part is the fastest delivery yet from his business to my door! Thanks Sir tomorrow it’s going into the skid. Can’t ride though because the top chain case bearing #*$&@ the bed.Waiting for parts.
JCviper
- Feb 27, 2016
- Morrice, Michigan
- 2016 SR Viper LTX-DX
- YAHOO
- jcstang06@yahoo.com
- Jcgoblue2
Is that 5 turns from stock setting? And this may sound silly, to the right?If you have ltx then steve is right and you are gonna need more. I am at 5 turns and it finally transfers some and thinking I might try 1 more to try and lighten ski pressure some more
5 full turns from barely tight installed in sled and suspension in the air. Yes to the right clockwise. Paint or mark one of the protrusions on the spanner nut closest to spring so you can see and count it in snow. 1/2 a turn matters and is noticeable.Is that 5 turns from stock setting? And this may sound silly, to the right?
JCviper
- Feb 27, 2016
- Morrice, Michigan
- YAHOO
- Jcgoblue2
Thank you Steve!5 full turns from barely tight installed in sled and suspension in the air. Yes to the right clockwise. Paint or mark one of the protrusions on the spanner nut closest to spring so you can see and count it in snow. 1/2 a turn matters and is noticeable.
