number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I'm just curious, what did he recommend?When I emailed Ian at monster performance he never even mentioned the exit shocks to me as an option which I found odd as he sells those shocks too. I asked for a set of 4 so maybe if exit doesnt have anything for the center he skipped that option?? He wasnt trying to upsell me for sure as the first package he priced me was the most budget friendly option/bang for the buck combo.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
On my 20 se the center shock is 1/2" longer than previous models. Price also tripled from yamaha for that shock for 20 and newer.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
That would explain why the Exit center shock was 1/2" to short then!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Which model are you saying this is for? 137" ?On my 20 se the center shock is 1/2" longer than previous models. Price also tripled from yamaha for that shock for 20 and newer.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
No because I compared the Exit shock they sent me to the shock off my 2017 LTX SE 137".. It was 1/2 short comparing to a 17 shock not a 20That would explain why the Exit center shock was 1/2" to short then!
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Got it. Thanks for the clarification.
One thing that I understand now is allot of you experienced on the procross are saying, this center shock might be smaller than the others on the sled, but it works harder to punch above its weight so it takes a beating.
Luke Lester from Snowtrax takes it one step further. On his Sidewinder video just this week, says he now believes its the most important shock on the sled.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Stage 3 elka fronts and stage 4 rears was his initial recommendation. Said stage 4 fronts would be even better with adjustable rebound if someone wanted to swing the extra $400I'm just curious, what did he recommend?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I have said this many times a few years ago. been on the procross since 2012 when it first came out.. Absolutely the middle shock on this chassis is the MOST important and needs to be rebuilt EVERY YEAR.Got it. Thanks for the clarification.
Luke Lester from Snowtrax takes it one step further. On his Sidewinder video just this week, says he now believes its the most important shock on the sled.![]()
justinator
- Mar 25, 2007
- Maine
I asked Ian about exit shocks for sidewinder and they do not have anything at all for trail models , just mtx sleds so the shock Jon recieved had to be for that. Hygear custom axis shocks are the same part numbers for 2017 up to recent . Isnt the limiter strap on 20+ models a 1/2" longer than previous models? Maybe the extra 1/2" in shock length is too make sure if strap is run on loosest position?
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Agree with you. I have mine rebuilt every year!
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Get rid of the light spring and your ride will improve and your shock will last longer . Factory spring, blown shock and you'll be breaking the front suspension cross shaft and then looking for a tunnel.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
That has to be the reason. If the strap has any tension on it it would not matter.Maybe the extra 1/2" in shock length is too make sure if strap is run on loosest position?
would the half inch matter at all EXCEPT on full extension?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Ran the triple rate raptor spring for 11K greatly improved things.. Agree with your post 100% Unless you weigh 175 or less.Get rid of the light spring and your ride will improve and your shock will last longer . Factory spring, blown shock and you'll be breaking the front suspension cross shaft and then looking for a tunnel.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I actually did not like the ride of the stiffer spring on my 129. I went back to the stock spring.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I've run the 150lb spring on my 129 for the past 2 seasons with stock valving. That spring is like a pogo stick on the big bumps.
I'll be having the shocks revalved this fall and I may try the triple rate Raptor or have the shock setup for the 150lb spring.
I like the handling characteristics with that spring. My dad has the raptor spring and it is definitely more plush.
- 6K
