stgdz
- Mar 27, 2021
- Buffalo MN
So I've had this problem most of the season and last year on my 2019 tcat. On square edges and some fast hits I absolutely blow through all my travel. It happens mostly on drive way approaches or when I try to skip over some bumps.
I tried to fix it by getting a raptor triple rate spring but while it di.helpnirndidnt.solve the problem. Ive been looking at the reservoir shocks and is there.much difference between the qs3 and the qs3r? The r doesn't have the rebound on the fts but does have the kashina coating. Are the components better in it? I really need a dsc equipped fts.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
What is your current FT shock and how is it set up and valved?
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
i had same issue with 20 T cat. the front shock is NOT fox... its a chinese look alike, replace it with a FOX QS3 or i did the one from 2016-17 XC 600 cross country shock... expensive but worth it. then switch back when selling and put on next sled. it has 20+ clicker
stgdz
- Mar 27, 2021
- Buffalo MN
its a tcat/srx so no resevoir and its stock vavlving.What is your current FT shock and how is it set up and valved?
MAx what do you have your clicker set at?
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
The front track shock sounds like it’s blown. I have Qs3r shocks on my LE, and the FTS never lasts a whole season for me after rebuild. I had it rebuilt prior to this season and she’s blown after around 3000kms. I have the bill mohr front track spring too which is stiffer than stock. If you’re going to buy a new shock, I would spend a little more and get a real Fox shock and not the oem version which are built cheaper.
