Hammer Down
- Oct 7, 2016
- Loudon, NH
- Sidewinder STX-DX 2017
Apex XTX 2012
I had a blown hand and thumb warmer fuse while ridding last weekend and I am curious if anyone else has experienced this? I . replaced the 20A fuse and was good for about 4hrs tlater blown again. I thenreplaced with A 30A for that was all I had . The warmers are still good after 8 hrs of ridding . Sled is going to the dealer soon but any heads up would be great!
THANKS
THANKS
Pstn head
If 20amp fuse is the spece'd fuse I wouldn't run a 30 in that circuit. Get a few 20amp fuses and replace when needed or just deal with frozen hands, that 30 could possibly cause a lot of issues becouse something wants to trip the 20amp that the 30 will not trip and that could result in burnt or melted wires.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Did your helmet visor cord short out on the frame at some point? same circuit.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I mistakenly had that happen last season. I noticed that the Backup Alarm, Dash Pod and tailight were also out. Replaced the 20A fuse and continued on. Once back home I changed the length and location of my visor cord.
Did not realize that the hand and thumb warmer were also on that same circuit?
Hammer Down
- Oct 7, 2016
- Loudon, NH
Apex XTX 2012
I like your thought but I run my shield through the cigarette 12v jack. The jack must be on a different circuit because I pulled the fuse and still power to the 12V jack.Did your helmet visor cord short out on the frame at some point? same circuit.
Good thought but ruled out at this point.
DanS
- Mar 3, 2018
- New Liskeard
- 2015 Yamaha SR-Viper STX-DX
My sled started blowing hand/thumb warmer fuses a few weeks ago. I've replaced the 20Amp fuse 3 times now. I thought the heated shield might be causing it, but the last time I blew a fuse I wasn't even using the heated shield. There has to be a short in the wiring somewhere. Don't know how I'm going to find it. I think I'll have to get the dealer to have a look unless anyone has any suggestions.
2015 SR-Viper STX-DX
Finesy
- Apr 18, 2017
- Manitouwadge
- 2018 Sidewinder RTX 50th Anniversary
2017 Sidewinder LTX SE
Exactly! The wife had that happen once on the 18 RTX 50th. I replaced the 20 Amp fuse, asked her go be more careful when unplugging her helmet and problem solved.Did your helmet visor cord short out on the frame at some point? same circuit.
Hammer Down
- Oct 7, 2016
- Loudon, NH
Apex XTX 2012
I brought mine to the dealer and they found a bad switch with pinched wire problem solved.
carolrayburnmurray
- Mar 11, 2025
- 2014 Yamaha viper and 2012 nytro
Hi. Did you ever find the issue. ? Same thing happens to me this past weekend on 2014 viper new to me. Looking for assistance before I have to rip everything apartMy sled started blowing hand/thumb warmer fuses a few weeks ago. I've replaced the 20Amp fuse 3 times now. I thought the heated shield might be causing it, but the last time I blew a fuse I wasn't even using the heated shield. There has to be a short in the wiring somewhere. Don't know how I'm going to find it. I think I'll have to get the dealer to have a look unless anyone has any suggestions.
wwolfe68
- Jan 16, 2015
- Ontario, NY
- 2025 Yamaha Sidewinder SRX LE #460
2024 Yamaha Wolverine RMAX4 Limited Edition
Have this issue on my 2020 ltx gt with heated seat. Blew 20a fuse and replaced. Worked for 10 miles blew again. Hand, seat, thumb warmers and helmet visor plug all on same circuit. Mine is bad seat heater. Took off seat and disconnected seat heater and no more blown fuses and everything else working. Been waiting on replacement sest heater for over 1 month and will be covered under YES extended warranty.
wwolfe68
- Jan 16, 2015
- Ontario, NY
2 sidewinders and 1 cat at dealer for all same issue service dept told me. Guess wiring gets brittle or wears worn and shorts out. Guess common problem according to dealer.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Very common problem. Usually where the wires bend thru the foam.2 sidewinders and 1 cat at dealer for all same issue service dept told me. Guess wiring gets brittle or wears worn and shorts out. Guess common problem according to dealer.
Turboflash
- Mar 18, 2019
- Southern MN
FYI - I had been waiting for replacement seat heater pad for a couple months. I was just informed they're back in stock.Have this issue on my 2020 ltx gt with heated seat. Blew 20a fuse and replaced. Worked for 10 miles blew again. Hand, seat, thumb warmers and helmet visor plug all on same circuit. Mine is bad seat heater. Took off seat and disconnected seat heater and no more blown fuses and everything else working. Been waiting on replacement sest heater for over 1 month and will be covered under YES extended warranty.
wwolfe68
- Jan 16, 2015
- Ontario, NY
just called my dealer....still showing Yamaha seat heater on back order. Not sure any difference between CAT and Yamaha for seat heater..guess it will sit and wait until it comes in...no hurry as snow is all gone!
