Some help from the s/c guy's. 04 warrior with mpi s/c kit. Just re-jetted and was running on stand to bring up to heat to adjust idle, ran a few
high rpm passes then shut off. Went to restart, motor cranks but gauge
will not light up and will not fire. The front 20 amp fuse in the fuse holder on the right side of the delta box was blown, replaced it but the insturment panel still will not light, cranks but no fire. Are there more fuses that i'm missing? Thanx for any info, Jerry
