michael432
started up our 09 phaser gt to load on trailer. let it run then a spin around the yard. sled died. nothing. got it in garage to warm up checked fuses and found ignition sure blown. replaced fuse an that one blew as soon as key was turned. ideas? thanks
First thing, check for corrosion where the ignition plugs into the harness then you will have to start looking over the harness.
