Bogey wheel specs
Going4It
South Lyon, MI
Can someone give me the size specs (OD, ID, bearing size etc.) for the front and rear bogey/idler wheels on my 2007 Rage. I would like to order some after market replacements but want to make sure I get the proper sizes.
unless yamaha changed them i don't think the bearings are removable\replaceable. for this reason i ended up goiing to a cat wheel which has replaceable bearings, but you will have to cut some of the back off the standoff as the bearings are a little wider. the wheels i used where a little taller than the yammi's which helps on slde wear also.
What he said.
Yamaha came out with replacable bearings in their bogey's last year (2010)
when I choose year on the Yamaha site ,it doesn't offer a years prior to 09 am I missing something?
Yeah the whole website changed since then! I'm assuming it's to push customers to the dealers more!
talk to travis (Hibishman) on here, he will hook you up
