Going4It
Can someone give me the size specs (OD, ID, bearing size etc.) for the front and rear bogey/idler wheels on my 2007 Rage. I would like to order some after market replacements but want to make sure I get the proper sizes.
unless yamaha changed them i don't think the bearings are removable\replaceable. for this reason i ended up goiing to a cat wheel which has replaceable bearings, but you will have to cut some of the back off the standoff as the bearings are a little wider. the wheels i used where a little taller than the yammi's which helps on slde wear also.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
700SCOTT said:unless yamaha changed them i don't think the bearings are removable\replaceable. for this reason i ended up goiing to a cat wheel which has replaceable bearings, but you will have to cut some of the back off the standoff as the bearings are a little wider. the wheels i used where a little taller than the yammi's which helps on slde wear also.
What he said.
Yamaha came out with replacable bearings in their bogey's last year (2010)
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
The spoked wheels in Yamaha's accessory page has replaceable bearings and the wheels work great! I've had a set on since '06 and they look like new yet with over 5000 miles on them. Here's a link: http://www.yamaha-motor.com/sport/acces ... etail.aspx
These also work great as well and have replaceable bearings:
sfcjeff
- Nov 7, 2014
- central wisconsin
- 2006 rs vector gt
when I choose year on the Yamaha site ,it doesn't offer a years prior to 09 am I missing something?
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Yeah the whole website changed since then! I'm assuming it's to push customers to the dealers more!
sfcjeff
- Nov 7, 2014
- central wisconsin
- 2006 rs vector gt
got ya thanks
- 16K
