markt111
I am doing some preseason maintenance and have a quick question,
are you guys using factory bogie wheels for replacement or using something better?
Pairodice
The hyfax seem to wear more even without them imo
Brent68
I put BRP wheels on mine. Inexpensive and have bearing covers.I am doing some preseason maintenance and have a quick question,
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
You wouldn't happen to have a part number by chance?I put BRP wheels on mine. Inexpensive and have bearing covers.
DMC
Fleecer
- Jun 13, 2014
- 2019 SRX
DMC
I just put a set of these: BRP# 503191316
Brent68
I think Fleecer provided a Part number. All I remember is they were for a 2008 model XP.You wouldn't happen to have a part number by chance?
DMC
DooZ
Aren't the Doo wheels a little smaller?
Brent68
Yes they are a little smaller. The ones I mentioned, from the 2008 XP, are less than 1/16” smaller. That was the closest match I found.Aren't the Doo wheels a little smaller?
baggs66
Do these fit the 19 models or are these for 17-18's, thanks timI just put a set of these: BRP# 503191316
Fleecer
- Jun 13, 2014
- 2019 SRX
17,18 Cats/Winders came with 5.65 inch or 143.5mm wheels.
19/20 Cats/Winders came with 5.5 inch or 139.7mm wheels, but they are junk!!
BRP# 503191316 wheels measure 141mm or 5.5 inches. 1.3mm bigger than 19/20 models, but 2.5 mm smaller than 17/18.
Smaller wheel = less waves in track under slide = faster speed!!
baggs66
I new the wheel diameter was different between the 17/18 and 19/20, but wasn't sure if the bearing was the same or not, thanks fleecer
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
I replaced a few with Kimpex part # 3604-039, time will tell if they hold up any better than the stock wheels on a 18 XTX. Seems the inner wheels get the rubber beat up faster than the outer wheels so i have all 4 mounted outside the rails to try. did anyone try to replace the upper wheels with something that may be better than stock? I did the JT rear axle and wheels when sled was new, wish they had quality replacement for the rest of the wheeks in the skid and the uppers.
Fleecer
- Jun 13, 2014
- 2019 SRX
Yes, the same 6004 bearing.
That is the Cat part number. The Kimpex number is 04-116-81 or 298891I replaced a few with Kimpex part # 3604-039, time will tell if they hold up any better than the stock wheels on a 18 XTX. Seems the inner wheels get the rubber beat up faster than the outer wheels so i have all 4 mounted outside the rails to try. did anyone try to replace the upper wheels with something that may be better than stock? I did the JT rear axle and wheels when sled was new, wish they had quality replacement for the rest of the wheeks in the skid and the uppers.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
On my Apex XTX I added the hyfax saver kit , which lowered the wheels .17,18 Cats/Winders came with 5.65 inch or 143.5mm wheels.
You noticed an immediate difference as it would roll down slopes , that it wouldn't on it's own before , and would coast farther to a stop when letting off the gas .
Less friction = faster speed !
Not sure about your less waves theory , as I noticed an easier rolling sled and no wave feeling .
Just my experience for consideration .
Anyone else use that hyfax saver kit ?
I wanted to get it for my SW , but can't find them anymore.
