petey_sx700
- Nov 17, 2013
- Central, WI
- 2017 Sidewinder LTX DX
2017 Viper STX DX 146
2013 Vector
2018 SRX 120
- West Central Wisconsin
scuba335
I have mine in the same spot.Here's mine in the flares as mentioned above.
Newfie viper
- Nov 18, 2014
- 2015 viper xtx turbo
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Here's the pics of mine on the Viper..
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
That's really clean. How is the guage held in the plastic?I have mine in the same spot.
scuba335
The hole you cut is smaller than the face of the gauge. Pop in the gauge and it will be resting on the larger ring you see in the picture. The gauges came with a u shaped plastic bracket (I replicated the bracket using a piece of aluminum) that mounts behind the gauge. The bracket squeezes the gauge against the plastic flare. Hope you understand this.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
For sure. That's how I thought you did. I'm Insyalling my innovate psb1 guage. I'll put a few pics when I'm doneThe hole you cut is smaller than the face of the gauge. Pop in the gauge and it will be resting on the larger ring you see in the picture. The gauges came with a u shaped plastic bracket (I replicated the bracket using a piece of aluminum) that mounts behind the gauge. The bracket squeezes the gauge against the plastic flare. Hope you understand this.
Byam
Thats where i put mind! Psb-1 innovate in Auto meter cup #2204
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Nice!!! I got my psb1 all hooked up. I'm just waiting on the mount
But I like your idea.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I finally got the psb1 install done.With the osp single gauge mount. I didn't like the way it looked with the small windshield.
So I made up a mount from scrap sheet metal and mounted it in the middle.
Now just wait for snow!!
I used autometer pods on either side with a simple L bracket that I made from some scrap aluminum.
Very nice install!!
4StrokeAddict
- Apr 13, 2015
- Michigan
- 2015 SR Viper LTX SE
What bag is that in the void in front of your handlebars. I really like that.I have mine in the same spot.
Edit: disregard, found them in the new Yamaha catalog.
dlinebacker36w
Which plugs did use BC I want to be able to unhook my easy to get hood off also I was gonna use butt connections but better switch to easy plug type of some sort and where'd u get them. Thanks
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
We got all my wire connectors from princess auto. Just used the good ones with heat shrink on them. It was pretty convinient to use the auxiliary jack for power. The connectors I used are easy plug types for taking the hood off. I can take a pic of the wiring if you want.Which plugs did use BC I want to be able to unhook my easy to get hood off also I was gonna use butt connections but better switch to easy plug type of some sort and where'd u get them. Thanks
dlinebacker36w
Yeah that be great I'm sure if I get a good pic I can find them best meWe got all my wire connectors from princess auto. Just used the good ones with heat shrink on them. It was pretty convinient to use the auxiliary jack for power. The connectors I used are easy plug types for taking the hood off. I can take a pic of the wiring if you want.
