Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
I would like to install a 0 to 15 PSI boost gauge. Is there an accurate point of connection that won't go into a vacuum? I plan to mount a plain autometer analog gauge / pod right on the handlebar riser. Sled is stock 2017 SW.
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
Mine is connected to to the boost line to the sensor near the manifold via a "T" and I've have no issues
Clintww
- Mar 6, 2022
- Central MN
- MN
It looks like you could connect a boost gauge to either of two hoses. Is it best to connect to the intake hose on top, or better to connect to the turbo output hose that is tied to the waste gate line which would be the bottom hose?
The left photo shows the hose coming from the turbo below the intake hose, the right photo shows the connection from the intake tubing.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Connect to one of the extra ports on the throttle body that are on the BACK SIDE of the throttle blades. If you connect anywhere forward of the throttle blades, you will not have an accurate boost reading (will read high).
Clintww
- Mar 6, 2022
- Central MN
- MN
The difference between the two would be absolute turbo boost VS. the boost actually going into the cylinders? At the throttle body I would see vacuum too which maybe is a plus. I will look for a port there. Is it capped currently?Connect to one of the extra ports on the throttle body that are on the BACK SIDE of the throttle blades. If you connect anywhere forward of the throttle blades, you will not have an accurate boost reading (will read high).
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Yes, I believe so. My tune has the boost gauge in the dash. My brother-in-law had a separate boost gauge and I believe that is where he hooked it up.The difference between the two would be absolute turbo boost VS. the boost actually going into the cylinders? At the throttle body I would see vacuum too which maybe is a plus. I will look for a port there. Is it capped currently?
stgdz
- Mar 27, 2021
- Buffalo MN
Just get one of the tunes
