canuck5
- May 5, 2007
- Sylvan Lake Alberta
- Yamaha Nytro MTX
I’m curious about spots you have found boost leaks on your sleds. Mine was in a very unlikely spot on inside of charge tube only found it by hooking up my air compressor to it. Was running the evo stage 4 tune at the time 14.8-16psi up at elevation. Anyone else have some on boost side or exhaust side they have found?
saskattakman
seen exact same place on a customers sled
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Not uncommon. @DranttelSS had the same happen to him running stock boost.
- Nov 29, 2009
- sabattus, maine
Do they rub on something in that spot?
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX (on order)
2018 High Country 9000
2001 SRX 700
Was hearing an exhaust leak Friday, so inspected yesterday morning and found the downpipe broken at the flexible.
canuck5
- May 5, 2007
- Yamaha Nytro MTX
It’s on inside of charge tube just before the airbox going to throttle bodies unlikely run spot from what I can see.Do they rub on something in that spot?
canuck5
- May 5, 2007
- Yamaha Nytro MTX
The boosted nytros use to always fail at the flexible bellows too so can’t say I’m too surprised. A bad enough exhaust leak usually sounds funny and if you cover your exhaust sled will keep running. This and large loss of boost too.
- Nov 29, 2009
- sabattus, maine
So the tubes are just failing there. I run aftermarket charge tubes but was wondering if I should check them for rubbing there. Doesn’t sound like the issue.It’s on inside of charge tube just before the airbox going to throttle bodies unlikely run spot from what I can see.
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
That's in the same spot mine failed and rubbing is not an issue in that location.
- Nov 29, 2009
- sabattus, maine
Stock tubes on yours?That's in the same spot mine failed and rubbing is not an issue in that location.
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Yep
canuck5
- May 5, 2007
- Yamaha Nytro MTX
I switched to Evo tubes but also thought it was a funny spot for it to fail on the stock ones.
- 7K
