SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
- '18 Sidewinder XTX-SE
I did find the problem, the solenoid was filled completely with water because it is the low point in the system. I ended up just cutting he vent line to the intake, plugging the hole in the intake and never saw a serious over boost all weekend.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
im getting the same scenerio right now, has anyone got pictures to show which lines to chk, i have all the upgraded WG actuator and .... well every thing TD offers for STAGE 6, mine shows 18-19 up to 1/4 mile then goes up to 23... i let off cus im only got 97 octane at that point.as my rpm droped as it prob pulled timing.
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
I think there was actually a yamaha service bulletin describing this exact mod... Not 100% though.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Two options. One(metal clamps) is a bit more difficult to remove if needed. Slightly harder to install as you need to get a good pinch with tool. Not sure how often a guy would be removing the hose/clamps? Plastic ones are probably easier option install and removal.Have you guys replaced the green clamps on the little hoses from solenoids? What clamps are you using?
I feel the metal clamps are less affected by heat cycling. BOTH are good options and better then the stock clamps.
Plugging the wastegate solenoid vent?
Has anyone had there wastegate solenoid vent plugged by dealer? I have 2 winders here both with plugged vent lines both had codes and this was yamaha recommendation (both stock at the time) One is stock and runs fine The second one is tuned and is getting only 13lbs on 270 with both hurricane...
zxtyler
- Dec 12, 2020
- Michigan
- 2020 SRX
If i don’t have moisture in hose or solenoid where else should I be looking for overboost problems ? I have My boost on my lowest setting I believe ms 16(250). Sustaining 18.3 and sometimes more. Changing settings makes no difference.
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
I had the electrical connector to the solenoid loose as well. I would double check the hose routing, some dealers have been royally messing it up and connecting things backwards.
Allen
- Feb 27, 2024
- New brunswick
- 2022 sidewinder
Have you find the problem i have the same issue SirIf i don’t have moisture in hose or solenoid where else should I be looking for overboost problems ? I have My boost on my lowest setting I believe ms 16(250). Sustaining 18.3 and sometimes more. Changing settings makes no difference.
zxtyler
- Dec 12, 2020
- Michigan
- 2020 SRX
It seems to be caused by moisture, either in the hoses or sensors. That’s all I could find,haven’t had that issue again. Of course I haven’t got to ride it more than 7 miles this year because of this nasty weather
Allen
- Feb 27, 2024
- New brunswick
- 2022 sidewinder
The bellows on it broke, it is a TD G1 header with around 1200miles on it. I was running the stock manifold tune with the stock header. No great pictures unfortunately, I was so pissed off taking the whole thing apart I must have forgotten.
Ok but the thing is were canceling by pluging the hose to it so that the westgate become macanical and we should not go over 10psi but we still get 16psi and that is on every stage 1 2 or 3 SirIt seems to be caused by moisture, either in the hoses or sensors. That’s all I could find,haven’t had that issue again. Of course I haven’t got to ride it more than 7 miles this year because of this nasty weather
Allen
- Feb 27, 2024
- New brunswick
- 2022 sidewinder
Have you find your problem having the hereThe thing is I was seeing 17-18PSI on ecotrail, powertrail and max spool 16... No real change between the 3.
Turboflash
- Mar 18, 2019
- Southern MN
Sounds like possibly bad MAP sensor? Boost should not be same on these 3 tunes.
Or the line feeding it, providing everything else has been checked. These can cause some weird results.Sounds like possibly bad MAP sensor? Boost should not be same on these 3 tunes.
Allen
- Feb 27, 2024
- New brunswick
- 2022 sidewinder
I know but we replace the 3bar map sensor and still getting 16psi but on stage 4 were getting 23 or 24 psi of boost and goes into safe mode .we reflash the unit back into stock and still getting 16 psi.we tough maybe it was a bad ecu but we tryied it in an other unit and gettting 10.5 psi of boost so not related to ecu Sir..
