yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
cool i will get you the dimentions tommorow morning
Dimebag
x2 on the dimensions! What kind of plate do you use? 1 mm / 2 mm?
yukon yamaha
- Jan 30, 2008
3 MM ALM.... <---4"----> 20degree bend <------10.5"------>
width was 13" it mounts to the cross bar that supports the turbo and the back of the tunnel... we install one of these on all our mcx kits
i hope this helps
i hope this helps
Dimebag
Do you have a picture of the plate?
yukon yamaha
- Jan 30, 2008
sorry guys i wont have any made for the nytro for at least a nother week
Dimebag
Does the plate block the whole turbo/ exhaust area? Im getting tired of the ice in my tunnel and this sounds really interesting
yukon yamaha
- Jan 30, 2008
almost all of it! We had it made for my short track turbo beacuse it would ice up so bad.... now it has very little ice in any condition.... If you have the option us 3mm alm it seemed to work the best
Dimebag
How do you mount the plate? Using rivets or bolts?
yukon yamaha
- Jan 30, 2008
I tapped holes and bolted into the turbo bar mnt and bolted it through the tunnel just so i can take it off if i need to
Dimebag
Thanks man. I have to take a look at it next week when i get my sled home again.. It ices up so bad i can't even see the turbo under there..
If you make another plate would you please take a pic, and maybe note the measurements on it also? That would be great.
Thanks again!
Thanks again!
