muskrat
Thanks for the reply, I will look into it and clean it.
MM
MM
sledneck22
BurrFabrication said:Most bovs do open at idle. Bovs are hooked to manifold pressure. When the throttle plate closes, intake goes to vCuum and bov opens! Sometimes depends on set up idle vacuum is enough to open the bov.
The ssqv bovs work on rapid pressure change. They are never open under idle or full boost just the change in pressure.
What kinda noise does your bov make thats soo cool?
A single woosh? Or multiple pftt pfftt pffft[/quote
I guess I can see that being the case. I guess my valve has enough spring tension that it doesn't open then. I guess I forgot i'm all plumbed into the manifold side of things...
ghost rider
Suspended
- Nov 13, 2013
- Muskoka, Ontario, Canada
- Rxwarrior
- Muskoka , Ontario
now I'm really confused….i thought if the valve was open to air at idle it would screw up the AFR?
and that it only opens when there is a drop in pressure at the carb (vacuum) and a rise in pressure on the charge tube.
but under boost both ends of the BOV have equal pressure……am i missing something?
Barry
Barry
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
I changed the BOV spring and now it expels the air great, however it clacks at idle…..like a bad hydralic lifter
then if i remove the clacking it doesn't open when the throttle shuts……….
WTF id going on…….help!
barry
barry
srxguy
Just installed a new Tial BOV and can't wait to test it
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
srxguy said:Just installed a new Tial BOV and can't wait to test it
I ran a tial wastegate on turbo car I had and was very impressed with the build and the quality.... BOV is probably just as good.
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
what about fluttering during idle…….like a bad tappet sound…..works fine under boost..????
srxguy
It works perfect and is not open at idle
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
tial is a solid company for certain…..did you have any space issues?
any pics?
any pics?
srxguy
Its on the charge tube, I will get some picsghost rider said:tial is a solid company for certain…..did you have any space issues?
any pics?
