Brake rotor seized
mtotguy
Montague, Michigan
2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
Last night I decided to install the 2015 rotor on my 2014 but found that the old disk is seized onto the shaft. I can't get any of my wheel pullers in there. I tried to tap a wedge behind the rotor but no joy. I put a little heat on it nothing worked. Any suggestions?
Just a question as it could have been missed.....but did you remove the little split ring that holds it on?
Using a wood block or lead soft blow hammer, tap inward, spray with penetrant.....
Yep. Removed the split ring. I have some Kroil on it now.
Since I have the extended warranty due to my early buy my dealer warrantied it. I put a good coating of anti-seize on the splines of the new disk before I gave it to him.
