scar
Amsoil 0-40 synthetic and a high performance yusa AGM battery in -27 degree celsuis.I won't ride past -27.Im getting old.After -27 I stay home and play COD.
scar
ranger1
Ok, its -32c outside right here & now, too cold for this dude to ride but I am curious to see if my sled will start, be right back.............
ranger1
......holy crap it's fricken cold!!! Anyway, full synthetic oil + 20 series battery, my sled started with no problem what so ever! Just turned the key & held it for a few seconds until I knew there was full ignition & the way she went, never even had to hold the throttle!
I always had hard cold weather starts with my 07 RTX but this thing seems to start way easier
scar
Just went outside and tried starting my 06 Apex.-29 Celsius here in Regina.After three tries she fired right up.Shut her down after a few minutes and went back inside to play COD
scar
ruso
- Dec 23, 2013
- Interlake, Manitoba
- 2015 Venture Tf, 2012 Apex xtx,
I just bought the red one 23.50 is that the cold weather relay?kidastra said:what about installing the cold weather relay? you probably already have it though
ranger1
Cold weather relay, hmph, wonder if my 06 Attak has that as it starts with no problem & the 07 RTX, if it did start, would backfire & make all kinds of racket before it actually got going, lol!!ruso said:I just bought the red one 23.50 is that the cold weather relay?kidastra said:what about installing the cold weather relay? you probably already have it though
Ultrafrozen
Yes, the red one is the solid state relay with no moving parts to freeze. I hear all 2014 fuel injected Yamahas have them.
The original ones had lube on the pivots that would freeze in extreme cold like you get up in the north. It's only -36C tonight and I'm thinking I'll change out my relays tomorrow just in case. Might have to throw a sweater on under the coat.
ratman
Ruso,
Although Apex's are 17k, they are not turn key and drive.
There are a few things not correct in dealer supplied form, and a few driving anomolies.
1. Stock sliders will wear out very fast. There is upgrade yamaha sliders called duponts. These last much, much longer.
2. Stock skis are junk and dart to the point of being dangerous. Upgrade tuner skis, or at least dual sliders are a must.
3. Stock fuel pump relays are prone to freezing below minus 20celcius. You should carry a warm spare to change out on cold mornings. (Skidoo had the same problem in 2005 to 2007
But they changed their relays before yamaha.)
4. You must wait about 4 minutes after starting your apex before hitting the throttle. It needs to be fully warmed up.
5. Never do a cold start and shut it off before it is warmed up. It may flood if you do
Other than these few repairable things, the Apex is limitless in the joy it can provide. I have the updates done, and it was flawless. The 2 doos i was with did start, but the etec overheated, and the mach developed flashing engine light.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
I don't know about the lube freezing as I've had the relay click and no fuel pump running. I think they get moisture in them.Ultrafrozen said:Yes, the red one is the solid state relay with no moving parts to freeze. I hear all 2014 fuel injected Yamahas have them.
ruso
- Dec 23, 2013
How cold is cold.........??
Dan
Dan
sideshowBob
-37c this morning in NWO!
This deep freeze just won't quit!
Ultrafrozen
We bottomed out at -40C overnight and I woke up late to -39C this morning at around 9am. Rough New-years, still recuperating.
It's warmed up pretty good now at -29C so I might venture out and take the Vector for a rip!
http://www.youtube.com/watch?v=F-glHAzXi_M
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
ditto on the -40C.
