Metallicat
The oil reservoir on my Vec broke tonight while I was trying to remove the oil tank drain plug. Instead of the drain plug coming out, the entire grommet or whatever the heck you call it broke off the tank. I was only using a standard 12mm wrench, didn't expect THAT to happen. I wasn't torquing it to death trying to remove the plug either. My wife is going to be pissed that I have to dump $250 into a replacement part (Port Yamaha). $250 for front end bushings last year and another $250 for this crap this year, I thought I was doing good only spending $150 on oil, filter, an idler wheel, and all new idler bearings this yr. Now this....
