Paystar
As I was gapping my plugs I moved the tank back a few inches to get to the plug on the PTO side. When I did this the weight from the tank shifted when the gas slashed. In doing so, it pulled on the gas line light and broke the rail at the 90 degree elbow.
I was able to track down a new rail and I’m looking for any tips for removing and reinstalling. It looks to be straightforward but as this winter has gone, when I say that it never actually is.
Cut the 3 zip ties, unscrew the regulator from the rail, unscrew the two Philips bolts and remove with washer? Will the injectors stay in the throttle bodies and only the rail will come out? Then put new rail on?
Looking for some tricks or anything to look for during this process.
Thank you in advance for the time!
Can you post pics of the break?
Turboflash
- Mar 18, 2019
- Southern MN
Injectors are only held in by o-rings (into fuel rail and by seals into throttle bodies. Once you've removed the two long screws holding fuel rail, you can just lift it up and injectors can either be removed or just hold them down and pull up on rail to pop them out. They can stay inserted into throttle body.As I was gapping my plugs I moved the tank back a few inches to get to the plug on the PTO side. When I did this the weight from the tank shifted when the gas slashed. In doing so, it pulled on the gas line light and broke the rail at the 90 degree elbow.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Not that it matters this time but for future reference , the plugs can be changed without moving tank..
Paystar
T
Thank you! I’m hoping to pull this off with no leaksInjectors are only held in by o-rings (into fuel rail and by seals into throttle bodies. Once you've removed the two long screws holding fuel rail, you can just lift it up and injectors can either be removed or just hold them down and pull up on rail to pop them out. They can stay inserted into throttle body.
Paystar
That would sure make life simpler.Not that it matters this time but for future reference , the plugs can be changed without moving tank..
Paystar
justinator
Like mentioned above this is a very simple repair. Youll have no issues. The right variety of extensions will allow you to swap plugs without moving tank in the future.
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
I just changed plugs this weekend on mine without moving the tank. My forearms are bruised from trying to remove and install the coils on the head. They came off hard and went back on very hard. Not sure I will do this again without moving the tank.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
once you learn a few little tricks not to bad to change plugs. But agreed so much easier with tank off!I just changed plugs this weekend on mine without moving the tank. My forearms are bruised from trying to remove and install the coils on the head. They came off hard and went back on very hard. Not sure I will do this again without moving the tank.
