svo11
In the process of changing tracks (backcountry) found the bolt that holds the bottom gears of the chain case was broken. Has anyone else found this or is this an isolated failure. Would not have found this problem if not for changing tracks.
Southern Renegade
- Jan 27, 2009
- Rock Island Arsenal, Rock Island IL
- 2009 Polaris RMK Shift 144
svo11 said:In the process of changing tracks (backcountry) found the bolt that holds the bottom gears of the chain case was broken. Has anyone else found this or is this an isolated failure. Would not have found this problem if not for changing tracks.
I had the same thing and if you do a search you will see others have too. It is becoming more common
Snoxracer242
Pretty much anyone that has taken their chaincase apart!
2009xtx
was doing the same to mine on saturday. bolt was sheard off in the shaft. boxed up the parts and brought it to the dealer and let them deal with it (warranty). hopefully have it back by the weekend
enticeraised
Found mine the same last night on xtx 09
