twiz28
- Nov 8, 2004
- New Brunswick, CAN
- 2017 Sidewinder BTX 1.75 Backcountry
2017 Sidewinder XTX 137
Anyone with the btx play with shock and strap settings yet? My btx came feeling very stiff, 115 psi in the front floats. Trying 10 psi decrease at a time to get to where I want to be. Haven't touch rear skid yet. Finding some push in corners but conditions are not ideal.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Havent made any adjustments yet but was a little stiff. Put on about 200 miles over the weekend and didnt change anything as it loosened up some. I'm going to put some more miles on before i start to adjust as it should loosen up more yet.
twiz28
- Nov 8, 2004
Cool, not much talk on here about the btx/mtx as compared to the trail forum. Keep me posted as to what you find and we can compare. Thinking of throwing some snow trackers on it as well, maybe just the saddles not the carbides.
I have not started fiddling with the setup yet but people seem to recommend to loosen it a bit in both frond end and rear shocks, one person recommended around ~75 psi main front and ~115 psi main back and keep the evol chambers at default psi (this is on a X-TX LE, don't think the B-TX will be much different?). I'm still very new to this so looking forward to what you guys think before starting to tinker with the settings. The center shock settings seem to be more complicated?
woodzynh
- Sep 11, 2012
- Nashua, NH
- 2015 Yamaha Viper XTX LE
They don't make trackers for the MTX skis...
woodzynh
- Sep 11, 2012
- Nashua, NH
210 miles, no adjustments yet but the dealer is good at setting them up. Debating on changing the skis
rxwhopper
anyone find enough time to play my btx le seems like a rock, very little transfer. my old xtx turbo transfered like nothing. i wonder if the 153 was a mistake? Has anyone played with the mounting holes in the tunnel? btx lower holes and xtx upper.trying to figure out if thats a issue? what limiter setting should i try?
rla1
- Jan 4, 2015
- saskatchewan
- 2017 sidewinder btx le
Message dieselxtx, he probably has a suspension setup that will get you close depending on your weight.He has seat time on trail, mountains, and on asphalt
customnytromtx69
The float 3 that came on my mtx i tried all kinds of pressures and couldn’t find a happy medium with them . I ended up swapping mine for exit x1 I was that unhappy with them . The rear skid shock I also swapped to exit . I changed the center shock spring to the cat 180 lbs spring as well . This will help with your transfer . don’t recommend moving the skid into different holes apparently causes geometry issues ! Also my dealer says that why my sled is wearing the rail tips .
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
What year BTX LE do you have the 17 with floats or 18 with coils?anyone find enough time to play my btx le seems like a rock, very little transfer. my old xtx turbo transfered like nothing. i wonder if the 153 was a mistake? Has anyone played with the mounting holes in the tunnel? btx lower holes and xtx upper.trying to figure out if thats a issue? what limiter setting should i try?
rxwhopper
2017 le 2.25 with evol3What year BTX LE do you have the 17 with floats or 18 with coils?
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
Ok same as mine and it doesn’t transfer the best stock here is my shock pressures I’m 190 dressed and have 2gal of gas on back and a bag.2017 le 2.25 with evol3
Front main 70
Front evol 150
Center main 55
Center evol. 125
Rear main 145
Rear evol 250
Rebound 8 clicks from fast
Limiter strap all the way loose
All pressure set at 55deg in my garage
I also cut my track down to 1.75 because on the trail I couldn’t hook up the 2.25 it would fold the lugs over and spin it is now a rocket and holds the skis in the air.
rxwhopper
im a good 100 pounds on ya but will try that.Ok same as mine and it doesn’t transfer the best stock here is my shock pressures I’m 190 dressed and have 2gal of gas on back and a bag.
Front main 70
Front evol 150
Center main 55
Center evol. 125
Rear main 145
Rear evol 250
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
You may need more air in the rear then I would try 150 rear main to start. I tried a ton of setups and none of them really made me estatic for the rear the front works very well but the rear I think needs a coil over shock I’m going to have a chance to ride a 2018 btx LE with qs3 oilovers on it and may be buying them for my sledim a good 100 pounds on ya but will try that.
shagman
Vendor
- Feb 18, 2014
I can add something for you to try. He center shock has a lot of effect on how the rear shock works. If you increase the pressure in the center you can reduce the rear and have a better ride. I’m 240 dressed and I run.
85 main/ 120 evol center, 125 main/ 140 evol rear. My front is close to yours. 75 main/ 110 evol. Also a little stiffer in the center the sled gets on top of the snow better when off trail.
Sent from my iPad using Tapatalk
