MT RX1 Mountain Man said:
You guys running the boosted RX-1 or APEX's would kind of time/life are you getting out of the other drive train componenets? (i.e., belt chain, gears, drivers) I keep thinking of boosting mine, but them part of my reasoning for buying a 4-stroke was for less maintenance costs. The last sled I owned was a Thundercat, what a money pit that thing was....
Belt life on the turbo the same as stock in my sled, it's all in the clutching.
I will expect chain life to be half the miles of a stocker, but I have no idea how long it will last. I changed out the chain when going turbo for my piece of mind, when checking the chain tension it has not streched much if any the last two seasons, will check it before I change the drive sprockets.
UPDATE: Checked chain tension, was able to tighten the chain 1/8 turn to fingertight.
I did not change out the gears as there were no visible wear to them, I'll check them as well.
UPDATE: No visual wear on the gears still like new. No metal residue in the bottom of the chaincase. I run motoroil in my chain case same as inside the motor, engine oil can take the heat from high speed running better than most chain case oils without degrading.
The WhalBros extroverts are junk, lasted two seasons and about 2000 miles, they started to melt last season when doing speedruns on the lake.
Speedo side drive axel bearing lasted one season, broke on my first ride last season. I will now change it before the season.
I will change out drive train bearings on a regular basis; like speedo side driveaxel bearing once a year, and all the other drive train bearings every three years.
