dexter
good stuff Phantom... makes me feel like it's worth while. Now all I need is some bushings as the oil lites are not ready and niether are the nylatrons. I am not going to put in the Yami bushings....
When you do get the old nylon bushings out in one peice, and you have a good bearing supply store near you, you might be able to buy the oil lite bushing right from them. There is only two sizes to worry about, so they might be able to fix you up. Remember that there must be a shoulder on one side of the bushing, to keep it in place...Good luck....Don PS. take your 2 long bolts to the store with you and this might help the retailer to determine the best size of the insde demension.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
All the bushings are plastic. There are bushings in the bulkhead and in the a-arms themselves. We will have a oilite kit that replaces every bushing in the front end (24 bushings total) available in September.
Question for SRXSPEC, will you be selling a kit for the bulkhead only [8 bushings]? thanks for the info....Don
