tonykof
I have a pair of C&A skis I was going to put on my Warrior. They are left over from my Polaris race collection ha! Anyway I tried to put them on the other night & found that the bushings have a smaller hole for the polaris ski bolt, no big deal, I figure, I can just drill it out a little & use my bolt from the Warrior.. Okay, that works but now I find the mounting seems to be higher on the C&A ski so the rubber block from my factory ski is loose & the ski will flop up & down... I looked at the "C&A yamaha mounting kit" & it basically consists of the 2 bushings, a bolt, washers & a nut, there is no replacment ruber block to go under it included in the kit.. So my quesion is.... What did you guys do? did you shim it? get a different block?
Thanks in advance
Tony
Thanks in advance
Tony
grader
i shimmed mine at the back so that the front of the ski was off the floor about 1/8 inch. a piece of a blown drive belt works well and you can put 1 or 2 screws in to hold it in place.
