I see you put sport tech hand gaurds on your sled. Can you give me some hints on how you got these to work? I bought them and all but planned on throwing them away. The brackets are pretty thick and i couldn't figure out a single way to get them to work?
do you have any advise or pictures you could share with me?
I just put the sportech's on my Attak ' had to wrap brackets in a rag and place in a vise and slowly twist the brackets,make sure you do it slowly, worked perfect.
I removed the installed the brackets and tightened them up. They were not flush with the top of the handle bars and sat at an angle. I then drilled out the 2 rivets that hold the handguards on to the bracket and bent the bracket down till they were horizontally flush with the handle bars and re rivited the handguars. Hope this helps...BBY
