Charged RTX
Do any of you guys know what the factory cam timing specs are for an Apex? I believe they are around 105.
TurboKeith
If I remember right they are around 100.
ultimate
- May 14, 2005
- ,Quebec
- uniklabels.com
- Yamaha apex
INTAKE CAMSHAft 109deg =OPEN(BTDC)33DEG
=CLOSE(ABDC)71 DEG
EXHAUST CAMSHAFT: 108DEG
OPEN(BBDC) 70 DEG
CLOSE (ATDC) 34 DEG
OVERLAP:67 DEG
06 APEX MODELS
ITS THE RIGHT WAY!!!!!!!!!!!!!
=CLOSE(ABDC)71 DEG
OPEN(BBDC) 70 DEG
CLOSE (ATDC) 34 DEG
OVERLAP:67 DEG
06 APEX MODELS
ptt
Guest
cams
Jay the one that I looked at was:
intake 230 duration 105 lobe center
exhaust 231 duration 99.5 lobe center
measured at .050 valve lift
I don't know what yamaha says.
Charged RTX
ultimate, Is this the factory spec or one you checked? Thanks
ultimate
- May 14, 2005
- ,Quebec
- uniklabels.com
- Yamaha apex
FACTORY SPECS.......all factory specs of snowmobile i have......i 'm connected in factory..............................
