smitty_j25
- Feb 2, 2015
- Nova Scotia
- 2014 SR Viper XTX
That's the answer I was hoping for, if I was to adjust both cams by 1 tooth they'd still be out of alignment, but in the opposite directionYou're holding your camera at a bit of an angle, but it appears you have it right. When they don't line up exactly, you always want them to be to the retarded side.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
If you can still see the "II" mark when the cams are aligned then you're OK. If it's one tooth off the "II" mark won't be visiable when the cams align. One tooth off significantly moves the mark far enough out of the window making it obvious its wrong.The
In the pic of the inspection window the horizontal marks on the cams are aligned, the first picture (showing the cams slightly off) was taken with the inspection window set exactly at the II mark. I'm trying to figure out if I should adjust 1 tooth before I put everything back together
When its off by a tooth the engine will still run without damage but it won't idle properly.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
