what would happen when riding with out limiter straps hooked up? The reason is because my apex mtn has no transfer until I unhook straps. With them loosened all the way they are still tight and I get no transfer
Simple answer, no. It’s not a matter of IF you will wreck the Center Shock, it’s a matter of when. If they break when riding back off the spring tension as much as possible and take it easy.
