GT44
So I struck a rock yesterday, got to love spring riding conditions. Dead centre , bent the plate on my subframe, ripped the skid plate that covers the oil filter area off and worst of all there is a grove in the lower engine case that is slowly leaking oil. So my question is can the engine case be repaired? or Does anyone know where I could get a used one, I can't even imagine how much a new one is going to cost.
arteeex
Lift the front of the sled and support it with a secure structure. Then rub the damaged area vigorously with a large stack of your local paper currency. It may take 2 or three applications.
09nytro
new one cost 131.53 and gasket 10.85 not to bad don't think u will find a used one but u could try AL'S Snowmoble parts 802-487-1000
Alatalo
- Jan 11, 2005
Did you crack the oil pan or the crankcase...?
The oil pan is $131, the crankcase is...well...let us call it slightly more expensive...
GT44
Looks like the oil pan, if that is what is exposed when you remove the skid plate, $170 canadian which I will be replacing not repairing. The engine case, which you have to buy as a pair is $2500. Won't know for sure until the engine is out.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
We can fix the lower case .it,s not expensive to repair but you can,t replace it without the upper case.they are a matched set
RealDeal
I had a similar case earlier this year when I hit something and it cracked my sump cover. I just took it off and welded it. Just cost me a new gasket, and time but who counts that! lol
GT44
Thnaks for the replies, looks like it is just the bottom plate, not the case itself. Hurricane if it is the case, I will be in contact with you.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
HURRICANE said:We can fix the lower case .it,s not expensive to repair but you can,t replace it without the upper case.they are a matched set
The crankcase halves need to be matched because it carries the crankshaft assembly but the lower cover is not matched to the crankcase. Yamaha sells it separate and it requires a gasket to seal to the case which means it can be used on any Nytro block.
Cast aluminum can be difficult to weld due to oxidation and contaminates. These engines run in extreme conditions and with all the vibrations and heat cycling there is a good chance the repair could fail. If you find someone to repair your cover they might guarantee their work but I bet if it fails and destroys your engine they won't reimburse you. For a few extra dollars you can buy a new one. They sell for under a $100 and you'll know it's right.
$87 at Yamaha Parts Depot, part#8ES-13417-00-00: http://www.yamahapartsdepot.com/fiche_s ... fveh=28688
The engine does not need to come out to change the cover. Remove the subframe and you'll be able to drop the cover with no problem. The frame will come out with a-arms and skis still attached and requires no special tool.
Mountaintech
You're lucky you didn't take out the heat exchanger as well. Sounds like it's time for a skid plate. BTW it's the same part for the Vector engine, so you could look for a used Vector strainer cover. I have a brand new one if you're interested.
- 8K
