snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
So what is the stock gas pressure to set the shocks to?Thanks for the info, I felt that my 18' has been soft since new. Luckily the factory high setting is about right for me. I've had the gas psi checked and raised a bit but no significant change. All my cats I've had with the same chassis would be on the low spring setting and still be firm.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I'm pretty sure Travis at BOP has them.
I still offer those. Uses a ss hex that is replaceable if it would strip. Also the adjustment hex is not on centerline of rotation so easier to adjust.
200psi but gas pressure is meant to help the seals seal and operate the ifp not hold sled up but it does very slightly. Most would not notice 50lb difference.So what is the stock gas pressure to set the shocks to?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Thanks steve,how has summer treated you,good I hope,but fall is fast approaching us,the older I get,the faster time seems to go.200psi but gas pressure is meant to help the seals seal and operate the ifp not hold sled up but it does very slightly. Most would not notice 50lb difference.
Been great. Working a lot but the weather has given me the itch bad now!Thanks steve,how has summer treated you,good I hope,but fall is fast approaching us,the older I get,the faster time seems to go.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ya me to,i find myself checking this site more and more,now that my sled mags have started to come in.Been great. Working a lot but the weather has given me the itch bad now!
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Does this require heating the leg up with a torch?I have bent the SHORT leg on torsion springs to further adjust them to my liking. 5k miles with no problems. Hygear does this also.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
There is a 5 position billet aluminum block available , for those who really need more torsion spring preload.The part number is, SMA-8JP39-BL-00. I should have included it earlier. It's in the Viper section of accessories, same chassis.
