gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
My friend ask me tonight if he can run race fuel in his 06 apex I said idk I told him I ask you guys on here
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
If it's setup for it.
- Jun 28, 2004
- Clinton, Wi.
Up to 2011 , all stock Apex motors are designed to run on 87 octane fuel. There are numerous posts on this subject. Without serious modifications, i.e. Turbo or supercharger, higher compression pistons, he'd be wasting money and power. Might not want to start to well either lol.
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
I know they make 93 or 98 race fuel can he run that
- Jun 28, 2004
- Clinton, Wi.
Again, why would you? He'd be LOSING performance , starting properly, and if they are race fuels, possibly lead fouling the spark plugs. There are absolutely NO advantages unless the motor has been modified . Ulmer posted dyno sheets showing a significant loss of power running 93, so anything higher would be even worse!
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
Yes you can run race gas in your stocker and yes you will lose some power. Sure smells cool though!
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Would it help to know that higher octane fuels burn COOLER then lower octane fuels. So when a motor is set up for 87 it will not be able to burn all the race fuel, it will lose power and like others are stating it will possibly be hard to start, foul plugs, etc. Conversely when a motor is set up for high octane, its because it runs so hot it needs the cooler burning fuel to keep the motor from getting hot and blowing apart.
I'm glossing over a ton of technical details but this may help it make sense to your friend. His motor is set up for the hottest burning fuel 87 octane, run that.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
It's seems very hard for some folk to get over the fact that Higher Octane does not equal more power. As stated above, you buy what your engine is tuned for.
