Can you weld Attak W Arm?
sure can..weld mine a couple of times also added some gussets for support..if you look around on here you find more info on this
X2 you could send it out to halfbake, they fix them and reinforce it and powered coat it for $225.
halfbake for sure... stronger than stock and will not break again... i've tried haha
I wouldn't say that I snapped one in half... After halfbaked did his work... Anything is possible...
RocketRollinSX said:
If I were to just weld it for now, can I just MIG weld it? trying to get out of tearing it down mid season.
Just weld it with your mig and it will get you through the season!!
You should weld it for now. FYI My brother replaced his this season and it has been redesigned and reinforced. This update came with a significant cost increase.
