DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I'm trying to get my driveshaft out to replace the bearing and check the shaft but it seems like my bearing is seized on the shaft. I've opened up the chaincase, removed the circlip and the 3 bolts in tunnel to try and get my rotor/caliper off but for whatever reason she won't come off.
Any suggestions? I dont believe I'm forgetting anything.
DMCTurbo
- Nov 12, 2005
Forgot to mention I've had it out before.
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Hmm. That seems odd. Did u take the caliper off first? That’s wat I did. The rotor was a bitch but got it with a couple pry bars at 180 from each other. It was a bit of work but it came. If your at that point, with caliper off, and she’s fighting you well that’s not good imo. Shaft is likely smoked. Do yourself a favor. Under the rotor there is a little depression in the housing. If there are metal filings in that pan like I had.......head for the dealer. That only happens when the rotor wobbles on the shaft.
Turboflash
- Mar 18, 2019
- Southern MN
Sounds like you hit on the head - the bearing is seized to shaft. Seized is akin to "welded." Depending on how severe it seized, you could be facing anything from having to cut it apart and getting all new stuff to, if you're really lucky, just heating up the bearing inner race to see if will expand enough to let go of the shaft. If you're lucky and this works, of course you'll need a new bearing but also check out the shaft closely to see how much heat went into it from bearing. Sounds like a mess. Probably will need at least a 12-pack of LaBatts.
SAB1
- Mar 1, 2011
- Tuftonboro NH
2010 Vector GT
2006 Apex
Labatts ! God haven’t drank that since high school
let us know how you made out but if u get caliper off and move out of the way shine a light in there at the bottom of the pan and look for fillings
DMCTurbo
- Nov 12, 2005
Do you mean splitting the caliper? I was trying to avoid that if possible.Hmm. That seems odd. Did u take the caliper off first? That’s wat I did. The rotor was a bitch but got it with a couple pry bars at 180 from each other. It was a bit of work but it came. If your at that point, with caliper off, and she’s fighting you well that’s not good imo. Shaft is likely smoked. Do yourself a favor. Under the rotor there is a little depression in the housing. If there are metal filings in that pan like I had.......head for the dealer. That only happens when the rotor wobbles on the shaft.
DMCTurbo
- Nov 12, 2005
There are filings but thats because I drilled out the 2 rivets holding the clutch guard on.Labatts ! God haven’t drank that since high schoollet us know how you made out but if u get caliper off and move out of the way shine a light in there at the bottom of the pan and look for fillings
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
If you split the caliper you will be able to pull the outer circlip on the OD of the bearing, you might be able to get the shaft out that way?
DMCTurbo
- Nov 12, 2005
Ok I've never split a caliper before. Anything I need to know?If you split the caliper you will be able to pull the outer circlip on the OD of the bearing, you might be able to get the shaft out that way?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
There’s a small o-ring in there don’t loose it.
Other than that nothing I can think of
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I split mine then removed the rotor then I was able to squirt penatrant into the bearing and it loosened up after wiggling it
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Shaft and bearing had substantial rust
DMCTurbo
- Nov 12, 2005
Ok thank you. I'll walk away for now and start fresh in the morning.I split mine then removed the rotor then I was able to squirt penatrant into the bearing and it loosened up after wiggling it
DMCTurbo
- Nov 12, 2005
I'm guessing mine will be the same.Shaft and bearing had substantial rust
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea good idea, frustration can cause tools to fly through windows!Ok thank you. I'll walk away for now and start fresh in the morning.
