rx1 turbo
- Dec 28, 2007
Just want to get some input on fuel injected mcx vs carb mcx. Carb sled has pistons, injected has stock pistons. Carb sled running 12 pounds boost, injected has 10 pounds. Who should get to the end of the lake first.
Turbo Tim
The one with the stock pistons will have the advantage (at those low boost levels )
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
The sled thats fastest will get to the end of the lake first. That is why we race.
sledheadgeorge
KnappAttack said:The sled thats fastest will get to the end of the lake first. That is why we race.
DITTO
sledheadgeorge said:KnappAttack said:The sled thats fastest will get to the end of the lake first. That is why we race.
DITTO
youngster66
end of lake.
I would think the sled with 2lbs of extra boost would get there first. Pistons are not a factor but 2lbs of boost is if turbochargers are the same size?
Set up!! 2lbs is nothing!!
Skydog
Skydog
TURBO TIME
pistons are a big factor, i would bet that 10psi with high compression will outrun 12psi and low compression!!!
snowy1
its all in the set up, I beat a sled running 18 lbs when I was running 14 lbs. the same compression on both sleds.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
If both turbo's are the same ,
pressure is pressure ,(boost)
compression is already in the equation !
The higher boost wins , if both set correct , traction etc !
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
rx1 turbo said:Just want to get some input on fuel injected mcx vs carb mcx. Carb sled has pistons, injected has stock pistons. Carb sled running 12 pounds boost, injected has 10 pounds. Who should get to the end of the lake first.
The Apex is way faster off the line even if running lower compression than the RX-1 which I believe the Apex does. If installed with the parts coming with the kit (2 head gaskets and a 0,059" headshim) the Apex will have CR of 8.94:1 and the RX-1 with 10:1 pistons and 2 stacked head gaskets will have CR of 9.13:1. Assuming both sleds have the clutching spot on the Apex will win. If the sleds are running the boost level you say, they will be pretty close in power, maybe a few hp in favor of the RX-1.
On the other hand I think you have the boost levels mixed up cause the RX-1 MCXpress kit came with the turbo preset at 10 lbs of boost where the Apex MCXpress kit came with the turbo preset at 12 lbs of boost. In this scenario the competition is over before it has ever startet, the Apex is the king. Then again it may depend on gearing and the distance you run, both running the same gearing nothing changes.
snowy1
rxrider said:rx1 turbo said:Just want to get some input on fuel injected mcx vs carb mcx. Carb sled has pistons, injected has stock pistons. Carb sled running 12 pounds boost, injected has 10 pounds. Who should get to the end of the lake first.
why is it you say the apex is faster off the line, I raced alot of turboed apex,s at the fairview shoot out and not one of them ever beat me off the line or anywhere else.
sledheadgeorge
snowy1 said:why is it you say the apex is faster off the line, I raced alot of turboed apex,s at the fairview shoot out and not one of them ever beat me off the line or anywhere else.
I will take a shot at this.....................ITS ALL.. ABOUT, # 1 HOOKUP & # 2 CLUTCHING.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
snowy1 said:rxrider said:rx1 turbo said:Just want to get some input on fuel injected mcx vs carb mcx. Carb sled has pistons, injected has stock pistons. Carb sled running 12 pounds boost, injected has 10 pounds. Who should get to the end of the lake first.
Well I have seen it the other way around. Depends on clutching and tracktion I would say. Here in Scandinavia (Norway, Sweden, Finland) all there is are the MCXpress kits, I have seen them all run, this is what I have seen on the trail and in the races. In the sanctioned races the Apex rules as well.
