benboat
- Dec 31, 2022
- Ohio
- Yamaha Apex
What is a good carbide for a 2006 Apex GT. Riding is mainly on groomed trails.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Bergstrom 8" triple points with ski shims!
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Aggressive snowtrackers. Follow the instructions. No darting, easy steering - like its on rails.
YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
I agree with earthling on the Snowtrackers.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Those are probably the two most commonly suggested options. As they just plain work.
If on a budget, a person could go with Woody's Dooleys. Go with a length that matches the rear. (with or without studs)
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
I have the same sled, same year and use Stud Boy Dually 6" with single host bar. They perform well and wear better than most other brands I have tried.
RobX-1
- Coldwater, OH
Although I wasn't running Stud Boy's Deuce bar, had their Shapers on my 08 Apex w/ USI X2 skis, I will be switching to Snow Studs Magnum Runners series bars after the success I had with running their Sniper Double Down Runners series on my 18 Apex w/ CurveXS skis. I too had found the wear on Stud Boy bars to be better than most but was very impressed with how well those Double Downs have worn thus far and decided to make the switch.
msgt van
- Mar 21, 2014
- Kasota, MN
- 2008 Apex LTX
I was using Bergstroms, but went back to Woody's slim jim doolies. X2 on the ski shim; it made a world of difference. Also, my carbides wear evenly across their entire length (both Bergstrom and Woody's).
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Pilot 5.7 skis with appropriate carbide length for however many studs you are running and 4" carbides in the outer positions on the skis. Proven many times to work well on the non-EPS Apex'sWhat is a good carbide for a 2006 Apex GT. Riding is mainly on groomed trails.
ski shim for sure and i run 6" stud boy shaper bars on my stuff but i am unstudded.
DARKMAN
- Sep 27, 2023
- Harris, MN
- 2013 APEX SE
1981 ET340 "Frankenticer"
1982 SS540
1981 ET250 Mod Oval/Lemans Racer
Heard of issues with pushing with the Woody's Slim Jim Dooly due to the round bar. I ordered Snow Studs Double Downs they look aggressive with square bar, have yet to see how they work. Price is reasonable as well.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Those must be the Double Down Sniper version then. The standard Double Down carbides use round bars.Heard of issues with pushing with the Woody's Slim Jim Dooly due to the round bar. I ordered Snow Studs Double Downs they look aggressive with square bar, have yet to see how they work. Price is reasonable as well.
DARKMAN
- Sep 27, 2023
- Harris, MN
- 2013 APEX SE
1982 SS540
You are correct, they are the sniper version.Those must be the Double Down Sniper version then. The standard Double Down carbides use round bars.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I tried to run those double carbide runners.
R R tracks stopped my sled in an instant.
No flex in the dual setup compaired to a single runner.
The dual runners will spear and send you for a ride...
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Looks like you just got unlucky. I had dualies on the apex for awhile and never had any problems with RR tracks. Not even sure how you could do it considering the rounded profile of the top of RR tracks so you got very unlucky, maybe you caught the seam between two track segments?I tried to run those double carbide runners.
View attachment 174057View attachment 174058
