np342403
I am experiencing the same issue. I have the chaincase cover, top gear, and chain off. I see the feeder tube for the reverse gearbox. Is there anyway to replace the tube and rubber gasket without pulling the top bearing and completely removing the reverse gearbox? Any help is greatly appreciated.
Vermonter
np342403 said:I am experiencing the same issue. I have the chaincase cover, top gear, and chain off. I see the feeder tube for the reverse gearbox. Is there anyway to replace the tube and rubber gasket without pulling the top bearing and completely removing the reverse gearbox? Any help is greatly appreciated.
Yes the rubber gasket that the tube goes thru is what needs to be replace but before you do that the holes need to be lined up so it doesn't continue to leak. Loosen up the chaincase bolts and align the holes with the reverse gearbox then install your new rubber tube gasket.
brad d
- Oct 31, 2011
Vermonter said:Yes the rubber gasket that the tube goes thru is what needs to be replace but before you do that the holes need to be lined up so it doesn't continue to leak. Loosen up the chaincase bolts and align the holes with the reverse gearbox then install your new rubber tube gasket.
yep thats what i ended up doing, no need to pull the seat or tank, i got the case gasket as well just to be sure there would be no leaks, and not a drop has come out.
np342403
brad d said:Vermonter said:Yes the rubber gasket that the tube goes thru is what needs to be replace but before you do that the holes need to be lined up so it doesn't continue to leak. Loosen up the chaincase bolts and align the holes with the reverse gearbox then install your new rubber tube gasket.
Did you guys replace the rubber gasket with the same P/N that was removed (90480-10012-00)? I see that it is a different P/N for the 2008's?
brad d
- Oct 31, 2011
i just picked up the gasket from my local yamaha, told him it was a 07
np342403
Does anyone have any thoughts on the GL-3 gear oil that is recommended? Most oils I see now are for GL-4 and GL-5 applications? I hear that GL-5 gear oils are potentially corrosive to softer metals such as copper...due to the EP additives.
The chaincase does have a few copper washers in it and potentially other softer metals I am not aware of.
What are you guys running in the chaincase?
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Yamaha Chaincase Oil.
np342403
Jeffz said:Yamaha Chaincase Oil.
I am currently using the Yamaha oil too. Just wanted to get thoughts on what others are running instead of the Yamaha chaincase oil.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
How do you realign the cases? I had the entire bulkhead off and now I've got a leak from the reverse tube.
