Sweeper
- Jan 25, 2015
- 2015 SR Viper Ltx SE
What kind of chain case oil should I use? Also how often should I change it?
Sweeper
Sweeper
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I am been using Amsoil Gear Lube in my chaincase. Its synthetic.
Good product and seems to hold up well. Also coats all the parts well, even after sitting for months.
I wont use normal 90 gear oil again.
MS
MS
Rye_Guy78
- Oct 31, 2014
- 2015 SR Viper LTX SE
I have used the amsoil, but now I usually just grab some yamalube chain case oil when I'm in to see my dealer, all depends on how much you ride, but normally change it once a year.
Sweeper
- Jan 25, 2015
How do you change the chain case oil? I took the exhaust off, what next?
Sweeper
Sweeper
Rye_Guy78
- Oct 31, 2014
You have to pull the cover off, there is a detailed how to in the FAQ section. Good to do it at the same time you change the engine oil. It's a pain in the #*$&@, but if you do it once a year at oil change time not such a big deal, and it lets you do a chain case inspection at the same time.
Rye_Guy78
- Oct 31, 2014
Chaincase removal and inspection
https://r.tapatalk.com/shareLink?ur...hare_tid=130877&share_fid=109789&share_type=t
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
i use a small hand pump and pull the oil out. this was you don't have to mess with taking the case apart.
Pstn head
Could you post a pic or the brand and model number if possible please, I'm having a hell of a time finding one. Thanksi use a small hand pump and pull the oil out. this was you don't have to mess with taking the case apart.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
The pump?
Then one I use is for taking oil samples. I'll take a pic of it.
trail traveler
- Dec 3, 2014
- Everett, WA
- 2015 sr viper s-tx-dx
2014 Venture MP
2016 RS Venture
2017 sr viper x-tx
3- 1990's era Arctic Cat prowlers
If you have a West Marine or similar type store near you, they should have a pump. I have one that is primarily used to change the oil in my boat motors. Something like this Model # 11097714 should work for you.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
For first change I would also do the pump and did but after that I recommend getting familiar with the inside of your chaincase. Yearly.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
I use any good quality gear oil and change it every season.
From what i have read, it seems that lots of people are sucking out the oil with good success.
Personally, i prefer to remove the cover disassemble most of it (within reason)and clean out all the shavings and crap that the magnets catch. Check out my chain and gears and Give everything a good looking over and reassemble
Im sure its overkill but knowing i did the best service i could gives me peace of mind and thats important to me.
I change out all driveline bearings every other year, and regrease them between changes. Again, i know its overkill
But overkill is a great thing when your ocd. Lol
x2!
Pstn head
Thanks, for sure yearly I go into the chain case and inspect and clean, it's just handier through the season to do a quick freshen up of the oil with a pump. I hate loosening the bolts a couple turns to drain and risk a leak.
Thanks again I'm gonna hunt down one of those pumps but not the penis pump LOL!
