kyleg
The plug above the tension bolt on the chain case keeps popping out i changed the top gear a few weeks ago added oil rode it for a few weeks then open the side panel And it was off put it back on rode again a few days later checked it and popped out again what could cause this has this happened to anyone else???
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
They wear out for one reason or another. Not sure why though. Buy a new one from the dealer and it should solve your problem. It's just a breather and if its not working it gets pushed out from expansion. I had the same problem and a new plug solved it
kyleg
K thanks will get one on order from dealer
Dr. FeeLGooD
Make sure the vent slots in your plug aren't plugged.
kyleg
It's clean nothing looks wrong with it
