Anyone have any tips on removing the chain case off my 07 RTX w/reverse. I will say Yamaha seems to have the most complex chain cases. I have removed many cases before and have never seen so many different parts. Not sure if there is a post describing the procedure, but any tips would be great. Thanks in advance.
langow
Check the "sticky" section under Apex FAQ there is a procedure with pictures for doing a gear change. This will get you inside the gearbox and back out successfully.
Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
removing chaincase is very simple worse thing is the nut that holds on the upper sprocket..Other than that it is very straight forward.. Pull off caliper firts..then hand brake caliper...Then take off snap ring spacer and shim then rotor comes off ...There is a spacer up on top shaft that has a setscrew in it..Remove that ...let reverse lever go from the pivot on the chaincase.. undo the 5 bolts then pull the cover off...Once inside very simple...
Maxout01
Yea it looks bad, but really not. Just dig in and you will be fine. Follow the stickies in the tech sections on this.
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
Besides the sticky post, what I got that helped me the most was having the parts diagram printed out. There are two diagrams that I can remember. One for the case and the other for the brake. Remember also if you get stumped just come post on here.
Subaru2006
Subaru2006
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
Do you have a service manual? If not go here to get it
http://www.filesend.net/download.php?f= ... d061b1df8c
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
It says the link doesnt work.
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
Weird. It has always worked before. The page opens but not the download. I'm uploading it again to th site. I'll post the new link in a few minutes when its complete. I'll also update the thread with the original download I did 2 years ago.
unclearpine
Service manual
http://www.4shared.com/document/KcyWZe1 ... anual.html
Try this is the service manual
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
new link is up and running as well.
bashley
When you're ready to remove the guts thake the gear sets out whole and run a zip-tie or wire through them as you take them off. This will save alot of headache trying to remember what order they were in.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
I'm sure your already using this, but thought, just in case?
http://www.totallyamaha.com/snowmobiles ... 20prt1.htm
thank you for the replies. I plan to get back to it on Friday Night with a couple of buds and beers.
offside
yamahatd said:thank you for the replies. I plan to get back to it on Friday Night with a couple of buds and beers.![]()
It very easy, first sled i own and have pick it apart many times for gearing. Take little picture with sell phone as you go. Look at the little spring between little reverse gear and the washer when taking of chain case lock. Pull chain case of a little, then turn it counter clock wise and pull it ut. The nut that hold top sprocket drive can sit much. take a friend and let him hold secundary as you take it losse. 90nm when instal it back
God luck / Tobbe
mr.pitstop
Its not that hard to do but I do agree with the OP. It is much more complex than any poo I have done in the past. I could change a track on a poo xc quicker with less parts removed than taking the chaincase apart on my ape.. Its not hard, its just complex compared to the other sleds out there IMO..
